Fob Antenna
Old Nov 6, 2018 | 06:06 PM
dlawj15's Avatar
CLS55 AMG
Fob Antenna
Key Fob unlocks only when the key if right over driver side door. Doesn't work from a distance at all. What can I do to fix this? Key has brand new battery.
Old Nov 7, 2018 | 10:46 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
For this fellow it was corroded batteries in the alarm siren:
https://mbworld.org/forums/w211-amg/...ml#post7511017
Old Nov 8, 2018 | 02:17 AM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
I was just reading about something simular,,,,
Poor key fob / keyless entry range – The key lock and unlock signal for the doors is transmitted via the rear antenna. The antenna is connected to the rear SAM module and a short in the wiring can cause damage to the SAM unit. If this is your dilemma, you may notice a blown antenna fuse. Especially if you replace the fuse and it keeps on blowing. Don’t use a higher ampere rating fuse to try to fix this problem.
http://www.mercedesmedic.com/mercedes-sam-module/
