SL55 Fuel Delivery issues
2014 E63s 1993 mazda rx7 on Boost
SL55 with 30k FP was low at mid 60s. Change the fuel filter and it went to upper 60 but still below the 70 PSI.
Installed this pump with filter problem solved.
the normal upgraded with, heads, cams and LT 200 cell cats.
https://www.protecfuelpumps.com/prod...ra-ii-sa44500/
I am thinking guys with Es running lean and thinking the need injectors might just need new filters or FP. I would of never thinkg at 30k car needed filters/pump.
Now I am thinking maybe I need to do the same on w212TT with 40k to be safe.
