First E55. A couple questions
1. Every time i open the drivers door, i can hear a buzzing which i have pinpointed to directly below the ashtray. Seems to run for a minute or two and then shut off any time a door is opened. Is this normal? What is it?
2. Keyless go does not appear to be working. The car had a completely dead battery when i bought it. Does something need to be re-trained or reprogrammed?
3. The radio navigation screen is messed up. I can source and OEM replacement for around $150. But i have seen some nice aftermarket android units as well. Are these plug and play with the fiber optics that are currently in the car?
Thanks for any help.
2. Unfortunately I missed out on getting a keyless go car, so can't help you there.
3. The android head units seem to be hit or miss. Most say they work well after getting through some initial installation problems. They are supposed to be plug and play, but many require some custom fabrication to get everything working. You will also probably loose functionalities, a lot of people report that the steering wheel buttons stop working. Others seem to be able to get them just fine. If you want true plug and play, I would just get a factory replacement. But the android units add a lot of cool features. It really depends on what you want.
Congrats on the car, post some pics when you can
2. Which part of your Keyless Go is not working? The door handles often go bad with time and need replacement (costly). The switch in the gearshift has a wire that often gets torn and needs a quick fix (cheap and easy).
3. Most all of the aftermarket units have issues with the fiberoptics. By far, the most cost effective and reliable thing would be to replace with a used OEM headunit and add a Bluetooth adaptor.
1. No idea
Worth investigating to eliminate as a cause.
I also determined that the buzzing noise I am hearing appears to be coming from a module that is attached to the CD changer. Anyone know what this is? Maybe it is faulty? I also noticed that my cd changer door button does not work. I had to manually raise the door myself to see the cd changer.
I also noticed there are two un-used or not plugged in terminals on either side of my shift boot. Anyone know what these are for, or what should be plugged into them?
I popped in a aftermarket head unit, installed by local sound shop for $900 bucks with rear camera (in 2016), Pioneer NEX4200 with Apple Car Play and does come with Android plug as well. Loved my Car Play! its like working your phone on your car screen! check it out. Shop took out fiber optic and rewired...
