HELP ME UNDERSTAND E55 COOLING!
Hey everyone. So this is my 1st supercharged vehicle so i am a complete noob when it comes to the IC and HE cooling.
I am currently running a single superflow pump exiting the ice tank pushing to intercooler. I just recently switched the pump to the superflow. Which brings me to my questions. #1 - Since I am running trunk tank do I still need to bleed the system? I understand how to bleed it but would i bleed and put it back into the normal coolant tank for the engine? Or since its the tank would i run a bleed line back and have it push into the trunk tank? (Sorry if this is a stupid question) #2 - Should I run 2 pumps? And if so where should i plumb in the other pump to flow to? #3 - Here is a picture of how my current setup is running for plumbing. Is there anything that I should change??? https://scontent-lga3-1.xx.fbcdn.net...7d&oe=5C6F4872 |
Originally Posted by Drew Durham
(Post 7618954)
(Post 7618954)
(Post 7618954)
Originally Posted by Alex L
(Post 7618978)
Yes, you need to bleed the system. Your drawing doesn't indicate the presence of a coolant tank though. Are you running an OE joint or a split setup? Either way you have to have a header tank above everything in the cooling circuit otherwise some air might be trapped in the intercooler and or HE.
With the working setup you shoudn't need to. Mine looks very similar except for the ice tank and pump location (I feed it from the HE). I wouldn't change anything but I would monitor and datalog to have an idea how well it all works in real life, not just on paper. I have no idea about the split cooling or OE. From what I can see there is only the Coolant tank in the engine bay on the drivers side. |
(Post 7618992)
According to logs it usually will run 17-22* over ambient with the current setup. It does heat up pretty fast though! But recover time is pretty decent.
(Post 7619017)
OE cooling circuit was designed to use a single coolant header tank for both, the intercooler and engine cooling. Many people separate the two but you would have to have two header tanks in this case. You can trace coolant hoses to see if yours still go into a single T-piece behind the radiator or form a separate circuit as per your picture.
(Post 7619042)
I'm fairly certain there is no secondary tank. So if this is the case its going to be a normal bleeding back into the drivers side coolant tank?
The tank will eventually self-bleed, but at a slower rate.
I don't know that you need to run two pumps, but I do. I run a Bosch 010 up front and a Johnson 2200 bilge in tank. My flow rate is very good with that combo. Flow diagram looks good. Same basic setup as mine, except there is a second pump after exiting the H/E. |
Originally Posted by Davednconfused
(Post 7619385)
What is the second pump going to do? Just curious. |
(Post 7620883)
(Post 7620883)
