BATTERIES: OEM or aftermarket?
#51
Received 1,467 Likes
The idea was the other way around: apparently the batteries mentioned here to be better quality and last longer are a bit more expensive and I said that is worth the extra expense, if we know for sure which are the better, long lasting one.
You kidding, right!?! 8-9 lbs extra weight won't make any notifiable difference to a car.
As for the faster bit, yeah, I was kinda kidding, but this is the AMG forum. There's some thread on here were someone replaced their battery with a 10 pound lithium one. Nowhere near the CCA or reserve requirements, but for mild weather, that 50 pounds makes it a tiny bit faster. For ultimate speed, I guess you could lose some weight, empty out the windshield washer fluid and only have a couple gallons of gas in the tank.
#52
I'm here with my 2003 SL55 AMG, the latest edition to the fleet
#53
I'm an electrical engineer. That's an interesting theory. I suppose the field could be stronger if it needs to charge a battery. But the reason the alternator dies is typically the voltage regulator which wears out and the bearings which are mechanical. I think having a bigger load load won't really affect the charging system, wear and failure is more due to mechanical reasons.
Also JCI does over half the batteries sold. At Pepboys, the Bosch is an Exide and the Champion is a JCI. Walmart might swap between Exide and JCI. Not sure about Autozone and Advance, could be JCI or Exide, just have to google search for them. JCI makes good batteries along with bad batteries on the same line as there's a range of 1 year, 2 year and 3 year batteries that they all sell. Usually the AGM batteries are considered more top line so they'll probably last longer as you can see from this thread.
I'm not an electrical engineer, but aren"t brushes subject to mechanical and electrical wear? Wouldn't they wear faster at higher load? My old battery would pull over 4 amps from the charger even after it was fully charged, so that would be on top of the normal electrical load of the car wouldn't it? Maybe 4 amps isn't enough to mean anything.
#54
thank you. was curious since i just had AAA replace my battery and didn't know what they put in. after calling them they mentioned they use Interstate batteries so this is what was installed. FYI...AAA installs batteries to your car if the battery has gone flat. The price they offer is cheaper than retail.
IMO. For me...I buy the best on sale (when the wife and kids aren't involved ) from who ever, wet or AGM. It's just another maintenance item that is an easy DIY I prefer a serviceable battery that I can top off once a year with distilled water. I also have a battery desulfator that I use once or so a year, to help extend battery life. In fact China freight has their "new" Viking series battery chargers on sale now that have a built in desulfator option. Either 25 or 40 bucks with coupon
#55
I have replaced the vr in all three of my mercs. One for the brushes, one just died, and one preemptively. FWIW the bearings in the ML alternator were still smooth and tight at 300k miles. It's over 330 now but I haven't checked it again.
#56
The “Platinum” AGM battery from Advance Auto I put in 5 years ago is already dead. this was for a GL.
Made in Germany
It was almost the same price as OEM. I decided it was better to buy the OEM this time, as the last one MA last almost 11 years. Plus, the OEM is made in Germany.
Disclaimer: I used to be a senior engineer at Mercedes R&D…
MA
Made in Germany
MA
#57
MA
MA
Did you just get the battery? Noticed the 1/2023 sticker so if you just did, it's been sitting around for a while. A fresh one is typically just one or two months old.
#58
The OEM maker of the Varta battery was Johnson Controls who sold their battery division to Clarios. Clarios has over 50 facilities worldwide. I think the AGM battery from Advance Auto is also from Clarios. So I think there's a few variables here, the batteries coming out of different factories, some might be better than others. Or just your standard cost cutting over the years and corners being cut or the purity of the lead/production isn't there. Basically I don't think you got anywhere by going to Varta instead of Advance Auto. Just one of those gambles either way. You might try Champion next time from Pepboys, also a Clarios battery, but it has a 4 year warranty instead of the 3 year like most other places. But if it only lasts you 5 years, it won't really matter. I think MB only has a 2 year warranty on parts. I still have the OEM battery in my 2008 over 15 years now, it's getting weak though, as soon as I shut off the engine, I leave. It'd be weak if I sit in the car with the seating heaters going and listen to the radio for a few minutes afterwards.
#59
I just purchased a new battery from Walmart (yes, I know....). It ended up being shipped directly from Clarios and was marked "Made in Germany". It is clearly a Varta and it had a longer warranty than any of the others and was cheaper by a fair amount. I would not normally buy anything for my MB from Walmart, but this did seem like a good purchase.
Can you share the part number or sku number and what it cost?
#60
$169 with free shipping. I had to pay tax and a $10 core charge.
My battery is to the right of the spare if you are looking towards the front of the car.
tlambert (04-30-2023)
#61
This is the one I purchased https://www.walmart.com/ip/EverStart...-CCA/380996471
Shouldn’t the + post of the battery be on the top BUT on the left (inboard) near the spare tire?
I believe that pic is wrong in that ad? Mine is a 05 and the car isn’t near me at the moment but I’m pretty sure it’s like I described.
#62
Yes battery on the right. Thanks for the info. And of course it’s out of stock now. Lol.
It could be that Clarios is waiting for another batch to come in from Germany. I'd check back in a few days if you can wait.
tlambert (05-01-2023)
#63
I don't know about the rest of you, but I got 11 good years out of my last OEM battery. And when it came time to replace it, I bought another OEM.
Yes, you might pay a little more on the front end, but you get a lot of years out of it in the back end. Not like some batteries that die after a 3-5 years.
#65
2005 CLS55 AMG W219 C219
Thats a long time! Normal life is about 6 years, so you almost doubled it.
I replaced both batteries for peace of mind, as I couldnt trust the last owner about the things that were supposedly done. I went with Exide
#66
Pmarino (10-08-2023)
#67
Previously, I thought the same as you. I believed that the OEM batteries had to be superior to the aftermarket ones. My resent research seems to prove they are not. I double there is a super-secret version that Varta sells to MB. I could be wrong, but it is unlikely. That said, the online price for a genuine MB battery is pretty reasonable. It is the shipping that kills it. If someone lives close to one of the dealerships that sells online at a discount it would be worth going that route.
#68
2006 CLS55 AMG, 2005 SLK 350 AMG
Exide is considered the worst of the 3 battery makers. East Peen might be the best, then Clarios and then Exide. East Penn isn't as big though so harder to find, mostly regional. Still there's many factories and battery maker isn't the only reason a battery would last a while. Still have the OEM battery in my 2008 E350, over 15 years now. Starting to get weak though. Got another car so no big deal if it can't start. Maybe next winter I'll get rid of it.
#69
Yuille, you know that MB does not make its own batteries. Varta is the supplier of them. Since Clarios owns Varta and batteries purchased through them in the US are marked "Made in Germany", it would stand to reason that they are the same battery with a different decal.
#71
Since we are talking about batteries and many of us use a battery tender, an AGM battery do not use the same charger as a standard wet cell battery. Any useage of a charger and/or tender must be proper for an AGM battery. A wet cell battery charger will shorten the life of an AGM significantly.
#72
#73
Pretty much any cheap charger these days like this Schumacher 8 amp charger for $32 also does AGM batteries.
https://www.amazon.com/Schumacher-SC.../dp/B07DM22XTN
#74
I use this on my cars that sit for extended time. Seems to work good and multiple settings.
NOCO GENIUS5
https://a.co/d/gWB0pej
NOCO GENIUS5
