Dry Compression results - cyl4 a little off
Old Dec 13, 2018 | 04:20 PM
redc36's Avatar
hey guys
just got a dry compression test done (115K on the engine). Fuel relay was unplugged. Car warmed up.
Cyl1 150
Cyl2 150
Cyl3 155
Cyl4 175 (passenger side by the firewall)
Cyl5 155
Cyl6 155
Cyl7 158
Cyl8 165
Q: Cyl3 -> Cyl4 diff of 20psi. Should i be concerned? What could cause this?
Old Dec 13, 2018 | 08:50 PM
ikrazyfoo's Avatar
09 E63, 92 VR4, 94 VR4, 85 MR2
Though the fuel relay was out, could have had some residual pressure. I wouldn't worry about it tbh. You can redo the test after you bleed off the fuel pressure and see if the results change.
Old Dec 15, 2018 | 10:17 AM
SICAMG's Avatar
2005 e55 AMG
Yes it is a little off but a least it's going in your favor and not down !!
Old Dec 15, 2018 | 04:11 PM
redc36's Avatar
My friend mentioned maybe a carbon buildup? Said add lucas fuel cleaner and do an Italian tuneup
Old Dec 15, 2018 | 04:27 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by redc36
hey guys
Cyl1 150
Cyl2 150
Cyl3 155
Cyl5 155
Cyl6 155
Cyl7 158
Cyl8 165
That`s not bad at all. How many miles?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 16, 2018 | 11:26 AM
redc36's Avatar
115K.
