Has anyone fitted a rear carbon diffuser from aliexpress on there e55 , mine arrived today and as I expected the quality isn’t the best I tried to put it on but the Fit is awful it seems the piece is too long by 20mm, has anyone else had this problem any ideas please
can you post any photo to show us what you’re talking about? I’ve recently installed SUVNEER CF diffuser, I removed the gray molding with heat gun and dremmeled the outline of the rear bumper where the gray molding had covered it. Doing so gave me a better fitting not flushed as I wanted but it looks alright for aftermarket. I messed up when drilling and I went all the way through the diffuser. So I used self tapping screws from cf side into rear crash bar, it’s solid tight on there. Will probably replace it near future.
My diffuser was a bit snugged before cutting gray bumper part out. But once I done it, diffuser had more room to fit.
There’s an old posting on rear diffuser install, that’s where I got the idea to take off gray piece and dremmel out the existing outline. I’m not on my laptop to give reference. Search threads for SUVNEER diffuser posting. Lots of good info and ideas!
I also haven't purchased a CF Rear Diffuser from Aliexpress. I purchased mine from Carbonbest.
Here are a few pics, not the greatest. The fitment was pretty good, but could be better.
Your never going to have perfect fitment, unless it's OEM.
looks good, did you had to zip tie the bottom sides?
Here are two close ups of the edges, I took this morning. If you look very closely, you can see the small gaps, so fitment isn't perfect but very close.
As I stated previously, you will never find a perfect fitting diffuser, unless it's OEM. Like the CF Rear Diffuser, that came on the 08 CLK63 AMG Black Series, now that's perfect fitment.
