E55 - oil in the coolant
W211 E55AMG
Hey,
I need your help because I have in my E55AMG (2003) a problem with the presence of oil in the coolant reservoir.
I have checked this oil and it is more like the color from the engine than from the gearbox.
The engine works correctly so I exclude the gasket under the head. If it would damage the main cooler, the oil would be the color of the gearbox.
Someone has an idea where the problem is.
bobgodd (07-27-2021)
2013 ML350 Bluetec
You might want to do a pressure test on your cooling system. You could also have your coolant analyzed for the presence of exhaust gasses. Might be a good idea to pull some spark plugs and look for signs of coolant (white deposits, IIRC). I'd not so quickly dismiss head gaskets; a car can run just fine with a HG on its way out. Until it doesn't. Just for kicks, take a sample of your transmission fluid to check for signs of coolant contamination.
W211 E55AMG
In m113k, the oil filter housing only has lines for the oil cooler and there is no connection to the coolant.
The answer he gave I’d bet is right, very experienced contributor in my opinion.
You’ve earned about a hundred passes for the times you were right and helped members here. My respect is not diminished at all.
Received 1,488 Likes
This place is a joke.
Are you sure about this. Because the engine motor m113k doesn`t have an oil cooler attached to the block. The m113k engine has an oil cooler on the right side of the front bumper. What you are writing about applies to the m113 engine (without compressor).
Also, old/dirty transmission fluid from the 722.6 can have an appearance of engine oil when it's floating around in the coolant reservoir.
W211 E55AMG
