power steering pump whine
Let it get a little low, I think the rack is leaking. I can't remember if it was atf or generic power steering fluid and the noise went away but now the noise is back with a vengeance. Did i put an incompatible fluid in or did I get air in the system or did the pump bearing just kick the bucket?
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
First off, is the fluid top off? Most often you get that dreaded whine due to low fluid level.
i think it was 80% chance it was generic auto parts store power steering fluid. I may of just put atf in there since I typically will use that. It was a month ago that I added it. I have not been driving it much
I have an 09 E63 and recently went rounds with my power steering. I used Febi-Bilstein Power Steering Fluid CHF 11S at $15 from Amazon. OEM and same manufacturer as the stuff above. I was told by multiple shops to switch our the reservoir first and see as the filter inside will clog and starve the pump; only way is to replace it. I picked up a new reservoir for $38 from mboem online parts or something like that. And it worked! quiet as can be.
regarding the pump, I was also told by multiple reputable shops, that it wont just be the pump pulley bearing that makes the noise, so you can rule that out. I did purchase a new pump from RockAuto as it was the cheapest over 6 or 7 our normal parts website at $240 or so (others wanted $400). Yes it's remanufactured but all them nowadays are and they don't make "new" ones anymore. Reman. is better than rebuilt (yes they are different I found out).
so do the reservoir first....took me like 30 mins to replace, then bleed the air out carefully; instructions are in another thread. results will be noticed fairly immediately if its the filter in the res.
