KEYLESS ENTRY ISSUE
HELP!
thx.
Oh and yes, they fail because water/moisture gets inside.
Cyrus
Cyrus
coming up with doing some quick research. Perhaps it will start working again once it has a chance to dry out? In the mean time, I guess I need to start searching for a new handle. Sort of sucks, I just got the car and have only had it for about 4 days and everything worked fine until today. Oh well.... thx
Thanks... What I found weird is that both buttons stopped and then returned at the same exact time. Perhaps there are multiple points of failure inside the handle that can cause one or both buttons to go out individualy, or farther up the harness, both at the same time?
This is common failure point with these cars, as the drivers door handle is the most heavily use part for entry and exit.
