Camber Arms
Camber Arms
Has any one replaced E55 stock camber arms with those from an E500 or E350? I think the camber would be closer to zero, and would save a lot of wear and tear on the inside of the rear tires. Anyone try this?
Received 1,487 Likes
This place is a joke.
Camber arms? The rear camber is set by the 2 upper control arms on each side. The long arm in the back is for toe. 320/350/500 upper arms will not fit because the E55 spindles use larger bolts to handle the power. There are probably thesame length arms anyways.
OK, that makes sense, the part numbers are different for the E55 from the other W211 platforms. How does an adjustable camber arm like this one work then? https://www.ebay.com/itm/Megan-Rear-...frcectupt=true
