E55 mods and maintenance
Old Mar 30, 2019 | 04:59 PM
55AMG.'s Avatar
2005 e55 amg
I have a 2005 e55 amg with 65,000kms I got at the end of last year. So far I have had a custom tune and 83mm supercharger pulley which took me from 245kw to 292 kw at the wheels, since then I have purchased PLM XL heat exchanger, Bosch 010 pump, UPD belt wrap kit and some de Filippo long tube headers, as this is sometimes my daily driver I want it to be as reliable as possible, is there any other mods or preventative maintenance that I should do at the same time or watch out for??? Any info or suggestions thanks in advance !
Old Mar 30, 2019 | 06:45 PM
PieRat's Avatar
CLS55
Motor mounts when you do the exhaust.
I replaced (preventively) intake temp sensor, MAP sensor and o2s to make sure the computer was getting good data for the engine..but that's me..
Old Mar 30, 2019 | 06:59 PM
mondo's Avatar
Alfa Romeo Giulia Veloce
only 245kw atw stock? man that's a lot of ponies escaped the paddock...
Old Mar 30, 2019 | 08:42 PM
tw2's Avatar
tw2
Do transmission fluid change (or full flush) replacing the gasket, pilot bush (very important) and filter. Engine oil of course. You will replace the coolant when you do the PLM, bleeding instructions are in the link in my signature. New belts and check pulleys, I already have a noisy stock OEM pulley at 48,000km. I replaced my IAT sensor but haven't done the MAP (it sucks to get to). Spark plugs (I have never noticed a difference even with twice that mileage on these engines) but leads are probably not necessary. Brake fluid if not done already (ideally every 2 years and a previous owner wouldn't have done it). Check your suspension bushes and fuel pump relay/fuse. Let us know how the headers look!
Old Mar 31, 2019 | 12:23 AM
55AMG.'s Avatar
2005 e55 amg
the previous owner had it serviced at 60,000ks from ec mercedes which I have receipts for including transmission service but I am unsure what this was as it was only $150 for trans service.next service is at 70,000 which I will probably take it to torque performance where I am getting the work done, yea was thinking bushes and fuel pump relay.
Old Mar 31, 2019 | 04:21 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
pilot bush???
Do transmission fluid change (or full flush) replacing the gasket, pilot bush (very important) and filter. Engine oil of course. You will replace the coolant when you do the PLM, bleeding instructions are in the link in my signature. New belts and check pulleys, I already have a noisy stock OEM pulley at 48,000km. I replaced my IAT sensor but haven't done the MAP (it sucks to get to). Spark plugs (I have never noticed a difference even with twice that mileage on these engines) but leads are probably not necessary. Brake fluid if not done already (ideally every 2 years and a previous owner wouldn't have done it). Check your suspension bushes and fuel g pump relay/fuse. Let us know how the headers look!
tw2, pilot bush??? Is that a small green rubber gasket that help prevent mental clicking noise when you're changing from park to drive, etc.?
Old Mar 31, 2019 | 05:10 PM
tw2's Avatar
tw2
https://vrpspeed.com/index.php?route...product_id=197
The one that stops transmission fluid wicking up the loom to the TCU.
Old Mar 31, 2019 | 05:42 PM
tlambert's Avatar
2005 E55 AMG
Electrical connector for the trans.
Old Mar 31, 2019 | 06:55 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
ah, no wonder why I saw/felt oil when changing my tuned TCU. is it difficult to change? And crucial thing to do immediately?
thanks!!!
Old Mar 31, 2019 | 07:14 PM
tw2's Avatar
tw2
I would do it in the next month. Reasonably easy, just take care as the conductor plate pins are delicate and don't overtighten the 7mm nut. Flush the loom with electronic parts cleaner.
Old Mar 31, 2019 | 07:21 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
sorry, LOOM? any pictures? if not, i'll look up.
thanks so much!!
Old Mar 31, 2019 | 08:29 PM
tw2's Avatar
tw2
thanks so much!!
Just the wiring loom going from the plug up into the car. Mine was dry, only the plug had transmission fluid on it so I gave it a spray out. The fluid can travel all the way up the wiring loom and into the TCU in the footwell if the pilot bush was leaking. New ones have different coloured o-rings so you can tell if it is original or has been replaced previously.
Old Apr 1, 2019 | 07:09 AM
55AMG.'s Avatar
2005 e55 amg
what kw at the wheels are they generally stock ??
Old Apr 1, 2019 | 07:50 AM
mondo's Avatar
i have no idea, but given they are 350kw at the crank, i would have guessed it to be at least about 280kw or so (20% drive train loss)
Old Apr 1, 2019 | 02:50 PM
tw2's Avatar
tw2
A lot of guys with good condition stock cars get 390-400whp which is about 292-300rwkw. Of course dyno's are all different so it can be very hard to compare. Your upgrade increase in power % seems about right though.
Old Apr 1, 2019 | 03:56 PM
PieRat's Avatar
CLS55
Most people use dynojet #. I havent seen a dynojet dyno in nz yet. 12% difference between dynojet and dyno dynamics brand for example..
Old Apr 2, 2019 | 08:22 AM
mondo's Avatar
yes there are a lot of different factors that come into play. the same car on the same dyno can make different numbers on different days.
