Airmatic Suspension
2004 E55
Airmatic Suspension
Since the Airmatic Suspension is software driven and since you can change the settings with a push of a button, would there not be a software package that you can install/switch out were you could up the stiffness if so desired. I would prefer to be able to select a stiffer setting at times than the stiffest setting currently with the car now?
suspension
sorry, I don't have an answer to your question. But, I wondered if the air matic firms up to the same degree when going around a curve, when it's in the comfort or sport 2 mode; basically, does sport 2 increase anymore, or is that the maximum.
E55, F550, S600 Ducati 999
www.ipn.com.au/mbworld/airmatic.pdf
