gear shift moves when accelerating ?
Old May 12, 2019 | 02:20 PM
new55's Avatar
04 55
just wanted to see if anyone else's gear shift lever moves under hard acceleration or is this a sign of needing new mounts ? if i rest my hand on the gearshift and jump on the throttle then i can feel the lever moving from the the motor.trans torquing -- i have not crawled under there yet but soon
Old May 12, 2019 | 03:23 PM
takeiteasy's Avatar
05E55-05CL500-02E430
for sure check you're mounts cant be anything ells
Old May 12, 2019 | 09:06 PM
tw2's Avatar
tw2
Rev it up in park with the hood open. See if your engine is trying to run away.
Old May 13, 2019 | 09:57 AM
new55's Avatar
04 55
LOL,, will do - i dont run it very hard so not to worried but will add to the list of maintenance items
Old May 13, 2019 | 10:19 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
most likely the trans/engine mounts are weak. could also maybe just be the shift bushings are worn out of spec
Old Jun 24, 2025 | 09:47 AM
Nabycls55's Avatar
C63 W204 and CLS55
Did you ever get to the bottom of this? my CLS55 does this
