Why does my AMG stutter and go zero rpm sometimes when i smash on the gas hard
Old Jun 7, 2019 | 02:51 PM
Mike2004 E55's Avatar
2004 E55 AMG
Cant figure out why when im at a stop, i smash on the gas and the car jerks, gets up some power and speed then goes zero rpm and no throttle response. At that point car slows down to low rpm and somehow kicks back into 1st or second gear then seems fine. Only other way i can explain is: it does the same thing when if u shift to manual mode and u dnt shift gear the rpms go full and throttle goes low rpm then same process. Please help thnx
Old Jun 7, 2019 | 05:03 PM
tw2's Avatar
tw2
No easy fix here. You need to get your car scanned with STAR. I suspect you will find transmission codes. Could be worn clutch packs.
Old Jun 8, 2019 | 10:04 AM
sjc246's Avatar
2005 E55 AMG, 2017 E400 Wagon, 2018 C350e hybrid
You need to check codes. My guess is a bad accelerator pedal position sensor, but it could be many other things.
Old Jun 11, 2019 | 01:08 AM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
If you have a bad pedal, I have an extra (that I replaced while troubleshooting something else...didn't change so it's still good). Reach out if ya need it
Old Jun 11, 2019 | 11:24 AM
05-E55's Avatar
2005 E55 AMG
Pedal. Just replaced mine due to same issue.
Old Jun 11, 2019 | 12:45 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
You may want to try the adaptive transmission reset.
  1. Insert you key, turn it to position #2, but don't start the car.
  2. Press and hold down the throttle to the floor for 5 seconds, do not release.
  3. Turn off the car, with the pedal depressed.
  4. Wait 2 minutes and restart, your tranny should now be reset.
Old Jun 16, 2019 | 12:32 AM
2004 E55 AMG
Thanks for all the responses. Appreciate any and all feedback. Looking into these possibilities 👍
