Replacing engine in E55
Old Jun 11, 2019 | 03:55 PM
Jessem13422's Avatar
E55
Will any M113k engine swap into a E55 ?
Old Jun 11, 2019 | 04:42 PM
FunkTron's Avatar
2006 CLS55
should be no problem
it's only the car specific bits like hose routing and such that you'd need to maintain from your e55
Old Jun 11, 2019 | 06:00 PM
E55
Ok, thanks. Thought that’s all it would be. just making sure.
Old Jun 11, 2019 | 08:50 PM
sjc246's Avatar
2005 E55 AMG, 2017 E400 Wagon, 2018 C350e hybrid
They will swap, but you may need to swap over your oil pan/pump. You may also need to plug a hole in the supercharger snout if the car the engine comes from did not have SBC (you can swap over the plug from yours, but a lot of people seem to have an issue with the factory plug leaking, so you may be better off welding it if you have the ability).
Old Jun 19, 2019 | 05:00 AM
E55
Ok, thanks for your help.
Old Jun 19, 2019 | 08:46 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
You will need your motor mount brackets too, if it is a non E55 engine.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
