Drive Mode Missing on IC
was messing with my scanner and must have coded something, now I can’t tell which mode I’m on From IC.
“Other thing to check is under programming, then central gateway. Check to make sure comfort automatic transmission is not enabled. If it is, disable and display will work. If neither of those works then I think it's more than a coding issue”
Here's another one . I have "One Performance" Dual Oil Catch Cans and I want to get them plummed in correctly so I don't cause any Issue .
There are not any specific diagrams on line that I can find anyway on the matter . There is one set of pics on here but they are unclear . I don't want to elliminate the CrankCase Breather all together but put them in line with the factory set up . One can for each side . . Any help with that would also be very appreciative . Thanks Guys !
Is your IC fixed with drive mode?
