Well! *That* was interesting! R350 story
Received 1,005 Likes
'99 and '05 E55 AMG
Got called upon to assist with troubleshooting a 2006 R350. Electrics were acting wonky (ESP errors, CEL on and off, headlights turning off individually, wipers working after turning off the key, etc). I ran a scan and numerous CANBUS and module errors came up. I went to check the battery under the seat and noted a small amount of water in the tray. Asked if any water leaked into the car in the last rainstorm and was informed that, yes, quite a bit of water poured out of the upper control panel and onto the floor during the other day's deluge. They had been sopping up water on the passenger side carpet. Hmmm, a clue. I lift the carpet and start to unbolt the floor panel and then…is that sizzling and crackling I’m hearing?
S**T! S**T! S**T! Smoke is coming out from under the floorboard!!! I hollered for a socket to unbolt the ground strap and of course a socket and ratchet were nowhere to be found! Minutes later manage to piece together a spark plug socket and ratchet and remove the ground lug under the seat. Whew! Finish pulling the floorboard and there must have been a gallon of water in there. ABS/SAM/whatever it was had sockets and connectors under water and the yaw sensor was definitely submerged. It appeared that the smoke was caused by a short between two power leads but I won’t know for sure until everything is dried out and put back together. Talked to the lady who inherited the vehicle from her late father and inquired did she ever see water leaking inside before? Why, yes. On several occasions. (Me: face palm). Told her husband to pull the modules, open them up, and try water displacing contact cleaner on the boards and the connectors and to call me when he is finished with it. Then, to see if the car can be put back on the road without too large an investment…at least the car didn’t burn to the ground….
eFifty5AMG (06-27-2019)
How does it get in? My wife's E seems to have water sloshing around in the trunk lid. No idea how it got in there. If it would ever stop raining I'd investigate.
I think the gasket or seal on the third break light on the trunk lid has a tenancy to start letting water in. I havent had the issue myself but I think I've come across discussions on that a couple times.
Most likely culprits for the front foot wells are clogged cowl drains that overflow water through/around the firewall. Usually around the cabin filter (the W202 has done this as well as my B5.5 Passat) Also check sunroof drains, door weather stripping, weep holes in doors. My 2nd gen EB likes to leak at the upper right windshield gasket, come down the A-pillar and douse my fuse box The W209 leaked on the battery tray and rotted it. Water intrusion.....My nemesis
2013 ML350 Bluetec
Good story, but I have to disagree with your last sentence "at least the car didn’t burn to the ground….".
"Too bad the car didn't burn to the ground" might've been the way I'd phrase it. Would've been the best thing to happen to it, given that now it's a money pit with punji sticks at the bottom.
