Track Day
1/8 Mile Drag Results
Hello all,
Went down to the local 1/8 mile track and ran my E55 a few times. I really need to work on my 60 foot times. I think what worked best for me was to stall it up before taking off (where I ran 7.5). Also, I ran in dyno mode, suspension on comfort and transmission in sport mode. Not sure if my times are ok for my mods. I've seen multiple E55s with a 1.6 60 foot with the same radials so I'm hoping to get there and get below 7.5!
Mods:
-77mm fsp
-raceIQ emailed tune
-Kleeman midlength headers to a ghetto muffler shop exhaust with x-pipe to factory axle back
-eurocharged large heat exchanger
-255 50 16 hoosier DR2 on E320 wheels with 12mm spacer and 40mm bolts
Next mods are going to be a trunk tank to pack with ice and a belt wrap kit. I have a nitrous express proton kit on the car setup for a 75 shot but I've yet to spray it as I need to install my wideband.
Advice and criticism is welcome! Thanks!
Mods:
-77mm fsp
The conversion calculator I used says your best time equals an 11.90 @ 115mph...I'm relatively new to the W211 E55 also, but the trap speed seems a little low...I was under the impression our cars did around 116 from factory?
EDIT: I just noticed the calculator I used said "This calculator is mainly for Naturally Aspirated runs"...so not sure how much difference it makes in the calculation
Those sound like strong runs to me. You're .7 quicker and 6mph faster than my completely stock e55 that ran 12.65 @ 112 in the quarter. Gotta think that yours would translate to at least an 11.7 @ 120
That's good to hear! Did you use some kind of calculator to come up with my approximate 1/4 mile?
just found a conversion chart and i was actually dead on to what they had. however, they converted my 1/8th to a 1/4 that was .15 slower than what i actually ran. so i think it's safe to say you'd be in the 11.6 range which is boogeying
Ohhhh nice! I really need to find a 1/4 mile close by to test those numbers!
