IC Pump Relay?
Old Jul 31, 2019 | 08:43 PM
RPB's Avatar
RPB
IC Pump Relay?
Hey Guys,
I hope you do not mind helping me out. My question has to do w/ my ‘02 C32; I tried to inquire in the relevant section although there is little action compared to here! I recently replaced the stock IC pump on my car because it was prone to early failure and no longer functioning at 67k. I went with the updated Bosch unit (010) used on the 211s. The difference in performance is mind boggling.
Would it be wise to also replace the oe relay? Any insight would be very much appreciated!
Cheers,
-Rob
Old Jul 31, 2019 | 09:56 PM
RPB's Avatar
RPB
No need to respond, I am going to swap it being that the replacement cost for the relay is nominal.
Cheers.
