Wrap the exterior silver trim with electrical tape
Old Aug 9, 2019 | 09:24 AM
87geeinn's Avatar
2006 E55 AMG
I know this sounds ghetto but I did it on my Grand National years ago before getting it repainted and after tearing off the body trim molding. Electrical tape is essentially vinyl wrap and holds up very well in the heat and temperature extremes. As long as you don't scrub the **** out of it and are mindful when washing the car, it will last quite a while and can be removed with little to no residue. It's easy to apply: Clean the trim and surrounding areas thoroughly with rubbing alcohol. Pull out 10-12 inch sections and lay it down without stretching the tape. It lays down nicely without bubbles and can be manipulated and stretched without kinking up. Then use the corner of a credit card or a guitar pick to work it into the seams and around corners. Next, use an exacto knife with a very sharp or new blade to cut it. Finally, use the credit card or guitar pick again to work it in a second time. You can do the entire trim in about an hour and a half taking your time. The front sections are a little tricky since they are wider than standard electrical tape. I opted to pasti-dip those two sections. You can also do the chrome edge above the license plate.
Old Aug 9, 2019 | 10:47 AM
jbaker1121's Avatar
MB: E55 AMG, CL550, E3004M Cab + other makes :)
if it works, it works. If you like the look can always paint them down the road.
Now it's time to black out the fender emblems to match the rest!
Old Aug 9, 2019 | 11:50 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Genius....I'm surprised that no one thought this thru before. You are very resourceful....
Old Aug 9, 2019 | 12:07 PM
Don Nguyen's Avatar
Former Vendor of MBWorld
Euros
Haven't seen people use electrical tape on window trim since I first started vinyl wrapping, around 2008-2009, haha.
Old Aug 9, 2019 | 05:15 PM
PJmak's Avatar
I thought about this long ago for my w202. never follower through lol
