2008 e63 rear drag radials
hello, I have looked around the forum but the information is not really definitive so I wanted to ask to be sure before I pulled the trigger on this set up. 18x9.5 with a 35et and 285/40 r18s, will this fit under the back of my car without a rub? thank you
Here are my setup....
2003 E320 16x9 with 255/50/16 Mickey Thompson et street in the rear.
Two E55 spares in front with Mickey as well. Check out my video at the track.
I have a set of 265/35/18 Nitto R888R that fit stock wheels and do not rub. They dead hook at the track. They are for sale for 350 plus shipping. They have under 100 miles and 5 passes.
The 265 from Nitto is almost an inch wider then a 275 Michelin Pilot Sport 4S.
I had a set of BFG drag radials in a 275 35 18 on a stock wheel on an 2008 E63 and they rubbed in first and second gear at the track when the car squatted. I do not see a 285 working.
so its only been like 6 months, but i did buy them, they did fit. It took a little messaging the inner panels of the wheel well but they did go on, they did hook and i went from a best of 12.71 to a best of 12.59. I do need to get better at burn outs as I had never done one in this car until pulling up to the water box lol, hopefully i get out more this year. I used grease paint to make sure I
didn't have a tire rub on a short little drive around the block
