Airmatic valve power supply problem.
Old Aug 24, 2019 | 05:58 PM
coobah's Avatar
'04 E55 Wagon
Hi.
I'm having a problem with my airmatic. Error code "5191 - Voltage supply of the valves..."
Compressor is fine as I can hear it working from time to time but my suspension can't raise/lower itself.
Any thoughts on where can I search for a problem? Which valve(s) does it say about?
I was studying WIS since two days already but I'm quite new to it. Couldn't find any "valve block" in there etc.
Really appreciate any help.
Old Apr 24, 2024 | 11:49 PM
BMWclapper's Avatar
1981 Mercedes 300CD 2008 Mercedes CLK 550 2014 Mercedes ML 550
Originally Posted by coobah
Hi.
Hi Coobah, did you end up fixing this issue, I’m currently dealing with it
thanks
Old Apr 25, 2024 | 12:36 AM
coobah's Avatar
'04 E55 Wagon
Yes and it was an easy fix. I just unplugged, cleaned and plugged in all of the airmatic connections on the struts/air springs and the control unit (under front passenger legs).
I was actually testing them for continuity and all of them appeared to be good, so unplugging and cleaning did help.
Old Apr 25, 2024 | 01:08 AM
BMWclapper's Avatar
I just did that and it worked.. thank god. Thanks a bunch coobah
Old Apr 25, 2024 | 04:49 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Cheap fix = good fix
