Performance package. Do I have it?
Old Aug 25, 2019 | 09:37 AM
Reine's Avatar
AMG E63 2010
Hi
How do I know if I have the performance package on my car? AMG E63 2007.
I just bought the car and what exactly is the performance package?
Old Aug 25, 2019 | 09:46 AM
tlambert's Avatar
2005 E55 AMG
https://www.vindecoderz.com/EN/Mercedes-Benz
Old Aug 26, 2019 | 07:56 AM
90lxracer's Avatar
01 E55
datamb.com
Old Aug 26, 2019 | 03:33 PM
Reine's Avatar
AMG E63 2010
WOW!! THANKS!
There were lots of interesting things.
Old Aug 26, 2019 | 03:38 PM
Reine's Avatar
AMG E63 2010
I like where is says: "N6T EXTERNAL NOISE CHECK AT PORSCHE" haha
Old Aug 26, 2019 | 11:07 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Post some pics and we can probably tell you if it's a p30 car.
Old Aug 27, 2019 | 12:00 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Originally Posted by Reine
Hi
If not, you can add all kinds of aftermarket performance power packages
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 27, 2019 | 06:49 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if you have Alcantara on your factory steering wheel, have 3 piece factory AMG wheels, and can leave 2 tire marks when you take off because you have an LSD.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 28, 2019 | 09:38 AM
Reine's Avatar
AMG E63 2010
Have all the AMG E63 2007 paddles on the steering wheel?
And my leaves 2 tire marks everytime.
The wheels are not original,it is Kleeman rims...
Old Aug 28, 2019 | 09:47 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
What hachiroku was simply saying, is that a common indicator that your E63 has the performance package would be an Alcantara Steering Wheel, AMG 3 Piece Wheels and a LSD.
Old Aug 28, 2019 | 09:59 AM
Reine's Avatar
AMG E63 2010
Yes. How do a Alcantara Steering Wheel look like?
I cant see inside the rear axle so I cant know that.
And the rims are Kleemann.
Old Aug 28, 2019 | 10:04 AM
Yuille36's Avatar
Looks very similar to mine, except it doesn't have a flat top or bottom, and the Alcantara is only at the 3 - 9 o'clock positions only and not on the airbag.
Old Aug 28, 2019 | 10:11 AM
6172crew's Avatar
E63 and GL450, ML350 bluetec
I have the P030 package, and my steering wheel is the same as Yuille described. The code P030 will be on the VIN readout when you google it. The limited slip dif and wheels are the other 2 things you can see. I have never seen a W211 E63 next to mine in order to see if the suspension is same, but the way my window sticker things reads, I have somewhat stiffer suspension than a non-P030.
