Check your IC pumps
Check your IC pumps
I replaced mine last July and just noticed some heatsoak after hard highway pulls the other night
Just data logged looks like it’s dead again!
IAT was 127 it’s 80f out and I got a circulation pump code for over-circuit overload in Star
thats pretty fun that it lasted less than a year
is this common?
Bosch 010 from FCP
is this common?
Bosch 010 from FCP
is this common?
Bosch 010 from FCP
is this common?
Bosch 010 from FCP
I've seen this pump recommend in other trends:
https://tecomotive.com/store/en/wate...0-2-water-pump
I don't know the difference between the pumps for sure but my understanding is that the pierburg pump have a higher flow rate? Does the pierburg use the stock mounting points?
Guess the pump has a mind of its own..just data logged and it ran perfect..
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/920x2000/20ddc54f_e15b_404f_b372_da874d231bb7_e420cd5d3d2f25e7e04d5188e076d704200a4209.jpeg)
The 010 pumps are suppose to have low failure rates compared to other pumps. I just replaced mine with the Bosch 010 and also a PLM large HE yesterday.
FunkTron (09-03-2019)
PLATINUM SPONSOR
I think I will design a wireless IC pump alarm, as so many people are driving around with bad IC pumps and have no idea.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
