E55 won't start
So my parents had reported this problem once before, but I have never seen it. We just stopped at a rest stop, and when I went to start the car back up, it refuses to crank. It shows all of the warning lights on the dash on when you try to start the car, there is a slight buzzing noise for a moment after you turn the key, but then nothing happens. In my parents case, it just started after waiting a few minutes. Not sure what will happen this time.
Anyone heard of this issue and know the cause? I should mention, the problem surfaced immediately after replacing the secondary coolant pump, and the engine has felt more coarse than normal today. Almost like the engine mounts are going out. |
You replaced CPS?
Originally Posted by Agent-A01
(Post 7879006)
You replaced CPS?
Crank shaft position sensor, common problem on these cars.
(Post 7879088)
I will have to look up the Crank Position Sensor. |
Your symptoms are definitely pointing at CPS
"it refuses to crank" (starter turns the motor or not?) "there is a slight buzzing noise for a moment after you turn the key, but then nothing happens" turning the key and starter does not engage??
Just did the CPS on the m112 (C320); Symptoms of CPS are car dies when it gets hot, then the the starter will spin the motor, but it won't start. Then after a cool down period the motor will start. (expansion from heat causes the a break in the signal from the CPS. Then when it cools, contact is made again....the signal is sent and the car starts. A no crank situation is not solely a bad CPS. You need to pull some codes. Need to know..... year and mileage |
Originally Posted by Pmarino
(Post 7879169)
Just did the CPS on the m112 (C320); Symptoms of CPS are car dies when it gets hot, then the the starter will spin the motor, but it won't start. Then after a cool down period the motor will start. (expansion from heat causes the a break in the signal from the CPS. Then when it cools, contact is made again....the signal is sent and the car starts. A no crank situation is not solely a bad CPS. You need to pull some codes. Need to know..... year and mileage The car is an 06 E55 Wagon with 118,000 km. |
CPS should be as preventative maintenance. I'm on my out the door, so I got to keep it short. Search no crank. Could be grounding strap, fuse, selonoid or starter it's self. Any CEL's?? (check engine light) Pull codes.
Check the starter relay as well. Check for corrosion too.
(Post 7879203)
Check for voltage to the starter solenoid....or jump the solenoid to bypass the ignition and see if she cranks. If it does not crank, you may have a failing starter.
Originally Posted by SICAMG
(Post 7879595)
Your problem is not even related to the CPS, so ignore that. Battery voltage, and cables? Go into UB Volt measuring mode, and check. Are you using a Key (EIS), or keyless go on the shifter?
Look at this, ( even though not exactly the same as your problem). https://mbworld.org/forums/w211-amg/...ont-crank.html |
1 Attachment(s)
Since the starter works by jumping it (as suggested by SICAMG), what is the voltage at the solenoid?
(Post 7879982)
Will report voltages tomorrow with a little luck. |
Enjoy your meal.... My guess is your starter or solenoid is on it's way out......starts fine....... heats up.....won't crank.....cools down...starts fine:popcorn:
Trouble shoot it when it's acting up. Forgot to say... next time it won't start, smack the starter with a hammer. You can get at it from the top of engine bay with a piece of pipe. If it works with the smack, it's on it's way out. |
Originally Posted by Bankroll
(Post 7879714)
What is the voltage under load? What happens to the voltage when you try to start the car? Have you looked at the fuses, relay, solenoid connections?
Originally Posted by feeshta
(Post 7878992)
Anyone heard of this issue and know the cause? I should mention, the problem surfaced immediately after replacing the secondary coolant pump, and the engine has felt more coarse than normal today. Almost like the engine mounts are going out. P.S. - I skipped ahead after the first 3 posts. Replace it when convenient, because it will happen again eventually. |
(Post 7881575)
Originally Posted by equitiesguy
(Post 7881873)
Your starter died. Same exact thing happened to me. Beat on it with a hammer until you hear it crank for a second to diagnosis. CPS is crank no start. No crank on these cars if the immobilizer is disabled during ignition startup = dying starter. Rockauto has the improved one from Bosch cheap. Sounds like a spaceship when it turns. Absolutely amazing.
(Post 7882488)
Can you explain how it's a dead starter when it works perfectly fine 98% of the time? Just curious.
You get all kind of weird symptoms of a bad starter. Short version: If you turned the key, and it didn't crank, it's either your battery or the starter. If it's the original starter, consider replacing it. If you want to verify the diagnosis then the next time it does it, hit it with a hammer. It'll crank, or turn over a few turns after you do and you'll know for sure. |
(Post 7882495)
Solenoid starts to go, or armature starts to fail. I noticed that my car would crank, hesitate for a half crank, continue to crank but ultimately not start. That was the beginning symptoms of the starter failing. Then eventually, it just died without warning, and wouldn't start.
You get all kind of weird symptoms of a bad starter. Short version: If you turned the key, and it didn't crank, it's either your battery or the starter. If it's the original starter, consider replacing it. If you want to verify the diagnosis then the next time it does it, hit it with a hammer. It'll crank, or turn over a few turns after you do and you'll know for sure. Where is the starter motor located on these cars, and would I be able to hit it with a hammer with the car on the ground? |
(Post 7882500)
In your case it sounds like the solenoid, so tap on that first. |
E55 not cranking!!
(Post 7879203)
Thx 👍 |
| All times are GMT -4. The time now is 03:09 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
