AFR measurement
Old Oct 28, 2019 | 04:01 PM
coobah's Avatar
'04 E55 Wagon
AFR measurement
Hi.
I'd like to measure AFR in my car. What's the easiest way?
- AFAIK there's no way to do it without an extra wideband O2 sensor with an extra controller and some tool which will monitor/show it's measurements isn't it?
- Where to put the extra O2 sensor? (does it have to be as near to cyinder head as possible or not really?)
- Does AFR monitoring AFTER the cats make any sense?
- I still have a stock exhaust system but my secondary O2 sensor monitoring is switched off. Can I somehow use the stock secondary O2 sensors for this purpose?
- If not, do I have to buy two separate O2 sensors and controllers for each side or maybe I could buy just one and weld "sensor bunghole" where both sides of exhaust mix with each other (near secondary cats)?
- Is the place where both sides of the exhaust connect (nearby the secondary cats) enough for such thing, or would it be better to weld some X-pipe in there?
Old Oct 28, 2019 | 04:37 PM
Sam.P's Avatar
'06 E55 / '10 GLK 350
Originally Posted by coobah
Hi.
Yes, you need a wideband to read AFR. Ideally you want it as close to the manifold as possible and it does not absolutely need to be before the cat, although it is preferable.
I’ve installed my wideband where my secondary O2 was for the right bank of the engine so I’m only monitoring one cylinder bank. Ideally you’d want to monitor both, but as cylinder 8 is known to be “leaner” I was OK with that.
Old Oct 28, 2019 | 04:45 PM
L*M*S's Avatar
E55 - Audi
I don't think there is another way that I'm aware of.
About 2 feet or so from where the gases exit the cylinder heads or Turbo, in an orientation of "Ten and Two O'clock" from the top of the pipe.
Before the cats only.
No they are narrow band and won't do the job.
One sensor could possibly work in the right position to get an equal sample from each bank but a sensor for each bank would be more accurate.
An X or cross pipe would possibly be better..
Old Oct 28, 2019 | 05:17 PM
coobah's Avatar
'04 E55 Wagon
Guys, thanks for clearing the things out a lot.
So... most probably I'll go with just one wideband. The question now is... Should I put it in the stock 2nd bank secondary 02 sensor place, or should I weld an X-pipe in place of stock exhaust cross section (just before secondary cats) and place the sensor there? What's lesser evil? Having the sensor right after the primary cat but on one bank only or having it further down the exhaust but in a a place which gathers both side gases evenly?
Old Oct 28, 2019 | 06:27 PM
L*M*S's Avatar
E55 - Audi
Thumbs up
If your gonna go with a single sensor and If your completely stock then I would go dead in the centre of this cross pipe, I've never tried this but I think its your best bet - good luck
