W211 Mercedes E55 Bent Spark Plugs?
Old Oct 30, 2019 | 12:43 AM
Rockfather's Avatar
2004 Mercedes Benz E55 AMG
Hello! 2004 Mercedes E55 with new motor (64k). Everything you can think of has been refreshened up (valve gaskets, oil, spark plugs, filters, mounts blah blah) Anyhoo I get a misfire in Cyl 1 after driving home and kind of pushed it. Ok... opened her up and found the two spark plugs bent. Had older ignition coils from other engine so swapped it, swapped ignition coil wires as well, and fresh spark plugs. Boom everything went well. Few days later we get a misfire again in Cyl 1. Opened her up and found the plugs again bent with some gravel like material on it. Any help please? Thanks!
Old Oct 30, 2019 | 01:33 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Are you running the correct plugs? That's obviously from the piston hitting them.
Old Oct 30, 2019 | 10:43 AM
coupesedan's Avatar
CLS55
Probably has a full E500 engine or maybe different heads. This is what happened to a member with an M113K block and N/A heads. Switch to short reach plugs with a colder heat range, the Bosch FR8s are way too hot.
Old Oct 30, 2019 | 11:19 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
After just seeing the photos, that was my first observation that the pistons are hitting the plugs, because their too long. Try shorter plugs, and your problem should be resolved. But also check the plug gap.
Old Oct 30, 2019 | 11:43 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Once previously a member had W210 M113 heads on his W211 M113K motor. Different length plugs in the two motors.
