airmatic line replacement
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Has anyone re-plumbed the air lines on their cars? With age and heat the original lines have to be suffering.
I imagine doing the rear would be a real challenge, but the front, including the pump to the valve block, should be fairly straight forward.
For grins I looked online for replacement hose, and obviously the factory part is expensive. But I also found lots of options for 100' rolls of nylon tubing around $20 per roll. This was the best I found:
temp range: -40f to 212f
max psi: 410
I found others with higher and lower max pressures, but the max temp was 140f-160f I thought that sounded a little low for the engine compartment.
I'm not itching to do this, I just couldn't find a thread that talked about this.
max psi: 410
https://www.partsgeek.com/catalog/20...lows_line.html I found this while looking for a new front airmatic strut this seems like a better more oem choice than that amazon one, maybe try matching the parts number on amazon
