W211 E63 Coil over coilover list parts needed - can't find
Old Jan 12, 2020 | 10:47 AM
1cerberus4u's Avatar
2007 E63
Maybe my brain works differently as the search function does not seem to help, or possibly its not on the list, but all I see is data on E55 conversions and not E63..
So, does anyone have a list or link to what is needed to convert a 2007 to coilovers?
Clearly;
Set of coilover shocks with springs (btw, what spring rate are folks using)
Rear control arms from E350
Someone with a computer to re-set CEL
What else?
Thanks!
Old Jan 12, 2020 | 11:54 AM
Dokus's Avatar
W211 e500 (Sold), w204 c180, w203 c180, w201 190e, W219 CLS 55
Which kit are you going to use? Arnott sells complete kit with everything you need. The only thing I'm unsure about is if you need e350 control arms with the Arnott kit.
Old Jan 13, 2020 | 09:44 AM
2007 E63
Not going to use the Arnott as I want height adjust ability... So Kw, BC or something similar that I can put adjust to
So, all I need are 350 rear lower control arms?
Thanks!
Old Jan 13, 2020 | 09:54 AM
Dokus's Avatar
You need to turn off the cel as you mentioned. Don't know if it can be coded out with star. Arnott uses a module.
