Heated Seat Issue
Old Jan 21, 2020 | 12:51 PM
jheadley98's Avatar
W211 E55 AMG
Heated Seat Issue
I have an 05' W211 E55 with the dynamic seats with heated and ventilated options. Starting this winter, I have noticed that the heated seat, at least on the driver's side, takes forever to warm up. Furthermore, the seat cushion, more often than not, doesn't warm up at all, just the back rest. Sometimes turning the heat off and on again helps, but I have not been able to diagnose this issue. Any help or suggestions would be useful. Not sure if I can replace the coil in the seat cushion.
Old Jan 21, 2020 | 01:21 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
You could have a broken wire in the heating element, that would explain why sometimes you have heat and sometimes you don't. You can but replacement heating elements, but it will require removing the lower cushion to install.
It is a DIY job, but I would take it to an upholsterer to get it done right.
