Transmission
Honestly mate it's a really easy job all the bolts involved are a t30 e torx, torque wrench (all bolts are same torque) and 7mm deep socket.. jackstands as well. You probably want a mate to help hold the valvebody but I did it by myself lol.. let me know if you want instructions
I'm just busy and it's easier for me to drop off the car right now.
I will order this...
https://www.fcpeuro.com/products/cop...on-service-kit
I purchased a kit from FCP euro;
https://www.fcpeuro.com/products/mer...n-001989680310
Review the following;
https://blog.fcpeuro.com/mercedes-7-...-transmissions
The bolts on the oil pan are single use torque to yield bolts, they should be changed evertime or you risk breaking the bolt if you reused them.
Regards
Joseph~
A flush will just replace the fluid and then start cleaning everything off and load the filter. Drain and fills will take much more time and work but also you can do it yourself as there is a drain plug and fill tube on it.
Then every other engine oil change, drain and fill and keep fluid nice and red.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
For a full flush I would be happy to pay the dealer.
