E55 with daily mods
before dynoed I gapped the spark plugs drove 150 miles for work and headed to the dyno.
mod list
long tube headers craigslight
76mm pulley OfferUp eurocharged tune
550cc injectors eBay
Issue list
it always says brake lights on when I start the car
no rear o2 sensors soo cel is on
Rear tires go out too fast
consumption of oil it smokes a lot after a good pull
She seems healthy for 200k let me know what I can do I still want to daily it 😁
Tire wear? Inside edge is from old sagging suspension and adjustable camber and toe arms can level the wear out.
Smoke can be from bad valve seals from wear . Do a compression test or leak down test to check blow bye, then you will know more about the health.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I have a oil catch can and collects a little bit of oil, is that considered "blow by"?
