Stephens 540 rwhp E55 package
Received 1,065 Likes
E55, GLS450, GL63, GLE350
E55 baller,
Let Paypal know immediatly. They can get your money back. I had a situation like this and Paypal camn through for me. I hope you can get your money back. He was a hot and heavy poster before you sent your money and since then..... utter silence.
Good news....I received all of the parts from Evosport today(Thursday) and everything looks great. Of course there are no step by step directions...no worries as I'll figure it out. The ECM was sent separately from powerchip and arrived today as well. Amazing service from evosport as I just ordered everything last Friday and CA is 3K miles away. The crank pulley is of high quality and should perform as advertised. Underdrive accessory pullies: crank, water pump, and power steering are also provided. The power steering pulley removal and installation requires a special tool as that is press fit. Amazingly, the crank pulley is not a press fit but it is snug. Once the motor is wedged from turning with a longer torque converter bolt, the factory crank bolt can be removed with a long breaker bar. Then, a small pry bar with some "side to side" action will remove the stock crank pulley. I've reinstalled all of the accessory pullies and have yet to finish the crank pulley as the keyway has provided me a slight challenge. I should finish tomorrow after work but no promises. Clearances in the engine bay are tight near the radiator even with the electric fan removed. If you have no experience with these situations, I would advise that you seek professional assistance. If the installation only required r&r the modified crank pulley(Renntech) this entire process would be much easier. Hope this helps and I'll adhere to my previous statement concerning the possibility of performing the install for nearby MBworld members.
Build date 2-04 E500
Originally Posted by e55 baller
How do you contact paypal. They hide all of their #800's
Sorry to hear of your troubles.... Paypal should be able to do something for you.
Here are some numbers....
1-888-221-1161 (customer service)
1-402-935-7733 and 1-402-935-2017 (electronic transfer questions)
I promise you these numbers will be alot less to call than stephens
Thanks for the Paypal #s. I will call them immediately.
I agree he should be banned but then again, he can just rejoin and potentially scam from another identity.
