No crank no start on e63 ??
If the starter is kicking out, and the engine refuses to turn over, it is either locked up ....or the starter is faulty regardless of any electrical issues I would want to know IF the engine is solid or not going by what the OP is stating.
I think we should all have a quarantine Zoom/FaceTime chat so we can work on this all together real time.
I'm going batty with nothing to wrench on or physically make.
0% of the time the problem is not being described correctly and we end up all over the place. I work in a dealer flat rate so time is money and speed is king !!!
ONE... turn the engine over by hand at the crank bolt to see if it is locked up. If it rotates in BOTH directions, move to number two.
TWO .... Jack up the car safely, Jump the starter at the starter terminals and see if it cranks and than you can rule that out that it indeed turns the engine over and starter works.
Than start looking into electrical issues .
At my shop this is a safer way to verify an engine problem before you start forcing the engine over. Again if it spins with the starter jumped, the engine is good to go, just chase the electrical aspects.
Also remember the OP is saying the starter kicks out and will not spin the engine. Big red flag right there. I wish him the best.
ps I can feel the starter relay clicking and I can hear the starter when we try to start the car but no crank .
thanks!
thanks
but before that even happens I wanna make sure the harness is still good by spraying electronic cleaner into the corroded areas .
