SRS light fixed? In a weird way?
Just when I think I have it fixed, the dang light comes on. Came on again today. So, I pulled everything off the top of the engine and double check all the evap vacuum lines. Everything looks ok but when I check the small vacuum line that connects the metal purge valve line to the back of the intake under the thrittke body, the hose just slid off with no effort. Clearly the hose is worn and hard. Got a new hose which fitsvon super snug now but for good measure, I secured both ends with a couple of little hose clamps.
The interesting thing is that I have also had an SRS light on. It has been scanning as a passenger seat sensor. After the fix above, the SRS light went off!!!
Can a vacuum leak trip an SRS light? Hopefully that is the case and I killed two birds with one stone. Fingers crossed.
