That green marked hose should NOT be around that side of those two hoses and NOT be held in place with that zip tie. Undo that clamp at the bottom of the expansion tank and route that hose where the red marks are. Once you do that. the hose should rest naturally at the bottom of the radiator/fan assembly.
