Seeking opinions or suggestions regarding a misfire
My motor has developed a misfire on cylinder 8 and I haven't been able to pinpoint the cause. Trying to rattle the braintrust here.
What I've done so far:
1. Swapped wires and coil packs to other cylinders to see if the problem would move.
2. Swapped spark plugs to see if the problem would move.
3. Tested resistance on all fuel injectors and also toggled them on/off with DAS. Resistance was good, 16-17 ohms for all. While toggled off, engine operated slightly worse.
4. Tested continuity of the coil pack wires back to the ECU, all good.
5. Tested compression on just the driver-side bank of cylinders 5-8, all good and matching at 10 bar.
I'm planning now to replace all spark plugs. I damaged a few in the process of pulling coil wires, was only able to replace them with close but slightly different models from the local store. I had 1 step colder so now there is a mismatch. Going back to normal plugs so they match all around in wear/type/gap.
My only other option will be to replace the fuel injectors, which are sitting on the workbench ready to go. I was hoping it was something electrical and I'd return them.
I've never seen an injector partially fail, usually completely bad or working, but I'm out of ideas.
If you have good compression ...that's very good to know ! You may have a sticking injector or a partially plugged injector. even though it will pass a continuity test, it could be defective.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
'99 and '05 E55 AMG
+1 ^
I've had fuel injectors cleaned and flow tested by both RC Engineering and diesel engine injector repair shops. Nice to get back a sheet showing the before and after flow rates and patterns.
It was injector! Running buttery-smooth now.
Took me approx 5h to do all injectors and all spark plugs, including cleanup around the engine. Hows does that compare with shop time
Cold start has been a bit rough, good otherwise.
I reset all the adaptations, hopefully that will help. Otherwise perhaps I'll try to get it re-tuned.
No misfire codes, but in Smooth Engine Running it is still which 8 is going out of bounds, but not enough to actually register codes. Rough, but not as rough when the failure was there prior to the repair.
No other errors on the ECU in Star.
Flat rate man !....got to love it !
I will swap my plugs out Monday or Tuesday and time it. I crack loose the plugs and then put the electric ratchet to it, never an issue and of course,manual ratchet to carefully tighten back up.
E55Greasemonkey (06-14-2020)
Yea I blow a lot of Nitrous through this engine and run 104 Sunoco fuel so new plugs every year regardless plus I can see how the cylinders have been running. Cheap insurance to prevent miss fires.
E55Greasemonkey (06-15-2020)
For reference USAG might as well be Harbor Freight. Garbage tools. You say it like you're proud.
Received 1,488 Likes
This place is a joke.
Now go watch some more YouTube oil change videos you shadetree hack! 😂
As a general note, it is important to double-check the gaps as there is plenty of misinformation out there on trusting "pre-gapped" single prong plugs.
Case in point, when I changed my plugs last weekend, 15/16 of the NGKs were completely off the factory spec out of the box.
In terms of difficulty of removal, maybe 2-3 required a little extra effort. Plugs were original to the car (15 years, 55K miles on them).
