M 156 engine timing chain information needed.
Good day guys, I need an M 156 engine timing chain replacement information.
I have a knocking noise in the morning.
Thanks for help!
Thanks for help!
I had the same problem recently. I changed an timing chain and the oil pump chain along with Tensioners. Now it's quiet and it works very tight. I also changed the gear of the crankshaft because it had worn teeth.
Kazannik (06-14-2020)
SPONSOR
2007 Mercedes E63 AMG
how many miles do all of you have on your cars? although timing chains are "lifetime" with most/all engines, it is required to be inspected at 100k and in shorter intervals there after. tensioner and related items lifespan will vary though.
