W211 headlight assembly
Old Jun 28, 2020 | 03:30 PM
Bob Neill's Avatar
Soon 2003 e55 amg
Has anyone installed VIPMOTOZ headlight assemblies for each HID? I notice that the igniter has a wire going to the ballast on the original OEM assembly. But the new headlight assembly did not have any wires going to it. Not sure how it gets power from the ballast to the ignitor.
Old Sep 30, 2020 | 02:04 AM
Maurice27's Avatar
Bob,
I purchased and installed a set of VIPMOTOZ HID headlights in my 2005 E320 CDI in 2018. They are very cheaply made. Installation and proper adjustment is nearly impossible because of the poor fit of the parts. Also I have had both HID ballasts fail, and VIPMOTOZ no longer carries the part or offers an alternative. It seems their "Lifetime Warranty" ends when the life of the original part ends. I am currently looking for a higher quality replacement and I haven't settled on one yet.
To answer your original question, the wiring for the HID ballast is included in their kit and is pretty simple.
Regards, Maurice.
Old Sep 30, 2020 | 08:04 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Is there a drop-in HID bulb replacement that works with the stock ballast and makes the headlights, well, better? Or is this a pipe dream?
Old Sep 30, 2020 | 02:26 PM
black06c230's Avatar
mgLipGD
to get the best of the stock setup use Osram CBB bulbs. If you really want to step it up then open the headlight and replaces the projector lens with a ZKW-R lens.
Old Sep 30, 2020 | 02:53 PM
kevm14's Avatar
Thanks. Can't seem to find on Amazon...
What's the deal with all these CBx bulbs? I guess they are still 35W? Higher color temp isn't necessarily desirable...curious how they are better.
Old Sep 30, 2020 | 03:08 PM
kevm14's Avatar
https://www.amazon.com/OSRAM-Xenarc-Boost-Headlight-66240CBB-HCB/dp/B0771VZ353/ref=sr_1_2?dchild=1&keywords=osram+D2S+CBB&qid=1601492866&sr=8-2 https://www.amazon.com/OSRAM-Xenarc-Boost-Headlight-66240CBB-HCB/dp/B0771VZ353/ref=sr_1_2?dchild=1&keywords=osram+D2S+CBB&qid=1601492866&sr=8-2
This?
7000K sounds really blue....
Old Sep 30, 2020 | 09:51 PM
mgLipGD
they are not blue really at all
I would suggest buying from theretrofitsource.com
Old Sep 30, 2020 | 09:54 PM
mgLipGD
Many on Amazon and others are fake
https://www.theretrofitsource.com/d2...cbb-B-66240CBB
Old Oct 1, 2020 | 02:08 AM
Fountain35's Avatar
Originally Posted by black06c230
Are those plug and play?
Old Oct 1, 2020 | 11:28 AM
kevm14's Avatar
Did some more reading and it seems that there are a couple of things going on with these bulbs:
- They are still 35W so they work fine with the stock ballast
- Somehow they are considerably brighter. At least one reviewer said the output and color is akin to a modern LED headlamp which would be incredible.
- They probably don't last as long as stock. But it may still be in the 3-4 year range which is totally fine. Plus I think ours are shockingly easy to change without removing the front bumper and other BS I am accustomed to.
- The 7000K is not really true....reportedly they are more like 5000 or maybe 5500 which is exactly what I wanted to hear. Didn't want 7000K
- They aren't technically legal for on-road use in the US....that means they must be good, lol
FWIW I do believe the Amazon link I sent was for genuine bulbs but point certainly taken on counterfeits.
Old Oct 1, 2020 | 02:42 PM
mgLipGD
for the nearly $80 price difference and I need 2 other pairs I am willing to try the Amazon link you shared.
Old Oct 1, 2020 | 03:56 PM
kevm14's Avatar
What about this?
https://www.amazon.com/PHILIPS-Xenon-X-TremeVision-Gen2-85122XV2C1/dp/B01M3SZ30L/ref=sr_1_8?dchild=1&keywords=philips+D2S&qid=1601582015&sr=8-8 https://www.amazon.com/PHILIPS-Xenon-X-TremeVision-Gen2-85122XV2C1/dp/B01M3SZ30L/ref=sr_1_8?dchild=1&keywords=philips+D2S&qid=1601582015&sr=8-8
Maybe just as bright?
Old Oct 1, 2020 | 04:45 PM
bobgodd's Avatar
2004 E55
What about this?
https://www.amazon.com/PHILIPS-Xenon...1582015&sr=8-8
I just put these in my car, replaced 5 year old (old style) Osram Night Breakers. I think they're brighter right in the hot spot, but they don't seem to put out as much light on the periphery as the Osram did. I'm going to leave them in as there's not enough difference to waste money on more bulbs, but for my next bulb I'll go back to Osram for sure.
