Blew my E55 Transmission Today (I think)
2003 W211 E55 AMG
Hi team,
I think my E55 transmission gave up today on my 2003 E55. Driving home, I went to pass a car, the power came on, then it went 100% off, then back on. Was very strange. Thereafter it felt awkward to drive, would shudder under load before shifting. I carried on home, drove about 10kms to a large hill near home, up the hill the trans wined, a lot!...….near the top of the hill, it started slipping bad. I couldn't get to the crest of the hill, pulled over. Then nothing, no forward back anything, just revs. Left it 5 minutes. Did a gearbox reset....then it drove again, but only 1st gear and slippage, a lot. Had about 2kms to get home. it did it twice again - the same.
At home, in the garage. I think it's a full rebuild - anybody had this experience?
Sounds not good. A STAR scan will confirm the need for rebuilding, I got implausible gear ratio. Might as well check your transmission fluid and definitely glycol test it.
2003 W211 E55 AMG
Thanks tw2, yes I'm not holding out much hope. I learned the 2003 have a weak link in the cooling system, I expect that what you mean regarding glycol and it being likely at some point to seep into the gearbox. I wish I'd known this earlier, especially as it took me not that long to learn this with some internet searching tonight.
The star scan, is this something I could have a mobile mechanic come and do to the vehicle while it's at my home?
I might look underneath for a drain plug and see if I can get some fluid out. Mercedes left me without a dip stick.
2003 W211 E55 AMG
Thanks, I'll have to see if I can find a mobile mechanic with the gear to scan it for me. the only way the vehicle is going anywhere further than my driveway is on a flat bed truck as it is. I was lucky to get it into the garage to be honest.
