Lights
Old Aug 24, 2020 | 08:04 PM
Slider's Avatar
04 E55 AMG
Lights
I need brighter (LED/HID) headlights and want to replace everything: side-markers, parking/driving lights, headlights (low beams and high beams).
I'm having a difficult time locating the exact bulb replacements and also determining the difference between good manufacturers and bad manufacturers.
What do you recommend?
Old Aug 24, 2020 | 08:34 PM
black06c230's Avatar
mgLipGD
well most the bulbs are 194 size just get canbus error free.
if you have HID XENON headlights then it’s a D2S size and I recommend Osram CBI or CBB from theretrofitsource.com
Old Aug 24, 2020 | 08:58 PM
Slider's Avatar
04 E55 AMG
I have an 04 E55 and am fairly certain the headlights are HIDs.
Thanks.
Old Aug 24, 2020 | 09:09 PM
mgLipGD
Thanks.
https://www.lastvin.com/
run your VIN and it will show All options
Old Aug 24, 2020 | 09:26 PM
Slider's Avatar
04 E55 AMG
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
Old Aug 24, 2020 | 09:36 PM
Slider's Avatar
04 E55 AMG
Headlights: https://www.theretrofitsource.com/d2...XNL?quantity=1
Are these the side-marker lights?
https://www.theretrofitsource.com/t1...T10?quantity=1
It says "parking lights," but these are too small to be the parking or "driving" lights.
Old Aug 25, 2020 | 07:23 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Most people don't realize that your HID bulbs, due in fact dim over time. So if your haven't replaced them say in the last 4 years your due. Simply changing the bulbs will definitely brighten your day. The E63 uses a Sylvania D1S bulb, and I would say that the E55 uses the same but unsure.
Old Aug 25, 2020 | 12:45 PM
AeonTheTerrible's Avatar
W211 E500
Both the side marker and parking lights are identical W5W/T10 bulbs.
If you don't have factory HIDs, I recommend the retrofit lab's kit
