Charging A/C after compressor replacement - light blinking
Old Sep 25, 2020 | 08:59 AM
JakeAndBake's Avatar
2005 E55 AMG
Just finished replacing my compressor, condenser/drier, and expansion valve due to a failed and locked up compressor sent shavings through the system.
Fast forward through that crappy job (the radiator/condenser/HE are such a pain to marry up correctly for mounting) and I vacuum down the system appropriately, and proceed to dump refrigerant in. Now, I’m just using some off the shelf bottles from a local auto parts store, but it should work. W211’s take 33oz and I purchased 32, figured it was close enough versus buying a third bottle to use 1oz.
My goal was to dump a fair amount in with the car off, then proceed to start the car and call for A/C to finish charging. Upon starting and turning A/C on, the light just flashes and my refrigerant is not letting me dump anymore into the line. So after a bit of googling it appears the cars have some sort of fail safe built in that will not allow the compressor to run if refrigerant amount falls so far out of spec one way or the other?
I’m ready to throw in the towel and take it in if this is a STAR only issue that needs to be reset in some way, but thought I would check in with you all before I quit. Any ideas?
Old Sep 25, 2020 | 09:12 AM
Sam.P's Avatar
'06 E55 / '10 GLK 350
You should have 35-45psi on the low side while the compressor is running. How much do you have? Is the system atleast keeping its pressure?
Is the compressor kicking on at all?
Usually the compressor won’t kick in if the car doesn’t see any or insufficient pressure...
I know there is some hidden menu on the AC control inside the car, may be worth investigating that.
Old Sep 25, 2020 | 09:34 AM
2005 E55 AMG
Thanks for the info. Compressor will not run at all so I’m not sure what the pressure is at. I’ll have to look into the secret menu!
Old Sep 25, 2020 | 09:51 PM
phunter's Avatar
07 e63
You will have to go in and clear any hvac codes to reset a/c function. I just had to do this when I recharged my ac after the motor was out
Old Sep 25, 2020 | 10:45 PM
2005 E55 AMG
Thanks man. STAR only or can a lesser diagnostic handle them?
Old Sep 26, 2020 | 09:21 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I would think any tool that can read all modules, so something like the iCarsoft should be fine.
