Manual E55
Old Oct 9, 2020 | 10:01 PM
greekstylist's Avatar
W212 E550 4Matic, W211 E55 AMG
Manual E55
This guy is from my area. Pretty amazing with Mercedes vehicles. Check his manual swap.
https://youtu.be/b_kwcEX8Pu4
Old Oct 10, 2020 | 06:08 AM
mondo's Avatar
Alfa Romeo Giulia Veloce
WANT!!!
Old Oct 10, 2020 | 08:38 AM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Is this the same guy who created the o-ring hysteria?
Old Oct 10, 2020 | 02:47 PM
MartinWake's Avatar
CL55
Yes.
Old Oct 10, 2020 | 03:22 PM
coupesedan's Avatar
CLS55
very cool
too bad i can’t afford it
Old Oct 10, 2020 | 04:41 PM
M5 LOL's Avatar
05 E55 (06 E55 RIP)
hahahhahahahah, exactly.
Old Oct 10, 2020 | 06:34 PM
What's the o-ring hysteria?
Old Oct 10, 2020 | 07:15 PM
coupesedan's Avatar
CLS55
guy blew up his twincharged m113k, supposedly oil starvation. he saw his oil pump pickup o-ring was hard and then bought another used e/cls motor with a hard o-ring as well. big nothingburger
Old Oct 10, 2020 | 08:12 PM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
He still was not wrong.
He clearly and concisely showed how and why it occurred. And it was clearly as he said it was.
Hardly hysteria. As these cars get older and if your pulling it and apart and in the area why not replace it?
As far as im concerned it was good information. What you choose to do with it is your bag.
An no im not going out of my way to replace them.
Old Oct 11, 2020 | 07:00 AM
If you look at his videos he built a race car from scratch. Frame and all. I believe he has a M113k engine in it with a turbo
https://www.youtube.com/watch?v=l9Li...ature=youtu.be
Old Oct 11, 2020 | 07:16 AM
SICAMG's Avatar
2005 e55 AMG
The guy has some awesome skills for sure.
Old Oct 11, 2020 | 04:19 PM
M5 LOL's Avatar
05 E55 (06 E55 RIP)
listen, I think we can all agree he's far smarter than most of us...if not all of us. but I disagree with his assumption that all 113k have this issue. these cars are OLD, like 14years in most cases. if this was a widespread issue we'd have thread after thread of car blowing up. most of us are all well over 100k miles and most cars are at least tuned. could it happen? sure. will it? the law of averages says probably not.
Old Oct 11, 2020 | 06:24 PM
austingtir's Avatar
Nobody on here is road racing one of these like he is. As he says in other videos he's going to dry sump the thing for obvious reasons. With the original e55 body I doubt it could generate enough g force for the pan to be a major issue but that thing hes got the motor in now certainly could if the downforce and slicks work.
Doing straight line pulls like 99.9% of people on this forum do is nothing compared to doing the same thing going around corners.
I dont think anyone has ever said they all have this problem I think he was just pointing out a potential issue.
Old Oct 12, 2020 | 01:55 AM
mondo's Avatar
the time attack car he has built is great. really good to see something different like that.
Old Oct 12, 2020 | 02:32 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
all o-rings on mercedes will have hardened over time. at 90k my oil cooler hard lines off he engine were leaking. replaced those o-rings and other o-rings lower on the hardlines on the process. the first and only thing i tell people regardless of engine is replace all o-rings. BTW, they have changed type at least for the M156. They went from a maroon colored to a black o-ring which denotes a different material.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Oct 12, 2020 | 07:56 AM
SICAMG's Avatar
2005 e55 AMG
All depends on oil changes and heat too. Both his engines clearly where very dirty inside to to very long oil change intervals. Add large amounts of heat and ???
Old Oct 12, 2020 | 04:11 PM
hachiroku's Avatar
SPONSOR
dirt has nothing to do with o-ring longevity. it has to do with the heat and amount of time the heat has been applied to the material. some harden, some shrink, some harden and shrink. no o-ring is forever, but matching the correct temperature range and material to use or function will prevent premature failure. some are specific oil or hydraulics whereas others are for water, some are for solvants, some are for air only.
__________________
-BARRY
Old Nov 6, 2020 | 01:00 PM
jheadley98's Avatar
W211 E55 AMG
This is actually my E55 he is doing the swap on. The swap is almost done as of now. Very excited to be getting the car back soon!
Old Nov 6, 2020 | 04:40 PM
tlambert's Avatar
2005 E55 AMG
Been watching the vids on the swap. Interesting for sure. Can’t wait to see the follow up vids.
Old Nov 8, 2020 | 08:16 PM
Old Nov 9, 2020 | 09:39 AM
slownrusty's Avatar
'06 E55 K2
This is truly great.
I completely respect the guys at XF Engineering for pioneering this tremendous effort and also jheadley98 for using his car as serial number 0001.
I look forward to the follow-ups on the SC issue and also software reprogram to remove the auto gear lever mechanism (plus cost).
Exciting stuff!
Old Nov 9, 2020 | 02:15 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I wonder if the same thing could be done for the E63?
Old Nov 10, 2020 | 09:54 AM
jheadley98's Avatar
W211 E55 AMG
He's mentioned that he is going to do the same thing with a W204 C63 so I would imagine it could also be done on a W211 E63 since it's the same engine.
Old Nov 10, 2020 | 11:38 AM
machild's Avatar
Top Answer: 1
2006 CLS55 AMG, 2005 SLK 350 AMG
I wonder why the OEM clutch pedal setup from another model within the W211 platform was not used. Clean integration and readily available replacement parts for future repairs.
Old Nov 10, 2020 | 11:43 AM
Yuille36's Avatar
I know that a C63 conversion would be awesome, literally "a thug in a suit"
