Extra Heat exchanger fitted .... in rear
So we all have the heat soak issue etc and I had an after market heat exchanger lying around... I bought it ages ago and cant even remember which one but think it might have been a Code3 performance bar plate to replace the front OEM unit.
Anyhow long story short I put the OEM one back in its place and with my water tank in the boot spare wheel well I noticed quite a bit of space inside the rear bumper area. I ended up fitting the code3 here even though there is no direct airflow it should be worth a few degrees of cooling none the less. The Johnson CM90 pump I have has enough oomph to drive both exchangers and the intercooler. So far been worth it; easy job overall - hardest part was getting bumper off.
So if you have a surplus H/E lying around this is a decent option - probably not an ideal location if you plan on buying a H/E specifically for this fitment and you also need to consider your pump flow rate .... Johnson CM30 or OEM may not flow enough and may make things worse.
I have a cooler behind my rear bumper with 2 Spal fans on it. I had to cut the aluminum bumper reinforcement for the fans to clear. It allows the air to be pulled through the cooler, then into the hollow area of the reinforcement and exit out each end.
Look in my thread link is in my signature.
stevebez (10-20-2020)
