hard start when warm
Old Nov 12, 2020 | 08:42 AM
Simon69's Avatar
E55 AMG CL55 AMG
Hey guys, i’ve recently come into contact with a hard start when the engines warm, takes ~5 slow revolutions to start. i have to let it sit for about an hour because sometimes it just won’t start. but when jumped with a jump box it starts like nothing. that’s what confuses me. unsure if it’s fueling, voltage reg, battery, any ideas before i mindlessly throw money would help. i run about 11.9 volts off, ~13 running and it goes back to around 11.9 when off.
Old Nov 12, 2020 | 04:39 PM
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
Crank position sensor possible?
Old Nov 12, 2020 | 07:06 PM
MartinWake's Avatar
CL55
Does it sometimes crank once stop for a second then crank again?
Old Nov 13, 2020 | 08:01 AM
Simon69's Avatar
E55 AMG CL55 AMG
EXACTLY
Old Nov 13, 2020 | 08:02 AM
Simon69's Avatar
E55 AMG CL55 AMG
did that a couple days ago with a bosch one from fcp cause it was pretty simple and cheap, took me 20 minutes but wasn’t the culprit
Old Nov 13, 2020 | 01:59 PM
MartinWake's Avatar
CL55
Originally Posted by Simon69
EXACTLY
starter 100% had the same thing happening to my CL500 changed the alternator, crank sensor, nothing worked until the starter..
Old Mar 21, 2024 | 03:52 PM
tomyyboyy's Avatar
2013 GL450
Hi, it seems that it is normal for "long starting" on the GL450 (2013) I replaced all my camshaft sensors and my batteries were tested at the MB dealer with them being fine. You stated that you changed out your starter and it ended the problem, has it held up? Has the problem returned?
Thanks,
