More Than A Hiccup, Calling All Diagnostic People!
My thought on the smooth driving with no boost is that it would just act like an N/A car, even with weird throttle positions it would still just be air-in and air-out without forced induction to make things exponentially more noticeable.
Full disclosure: working with multimeters is not my strong suit, but I get by. I back probed the TB this morning and checked for power supply. Now, according to the post pic below, this is our wiring pinout for the TB. First oddity: I got 4.76 volts at pin #6 with it unplugged, so this is my power supply. Ground is pin #3. So already this info below is wrong (and could have just been mis-posted). Since pins 1 and 4 are mirrored on the opposite end, you'd almost think it was plugged in backwards but the flat end on one side of the cable makes it impossible to do that.
Then I back probed pin #4 with it plugged in, see video below. It goes up to about 2.5v (about 30% through the pedal stroke, when the butterfly is now wide open) then drops to almost nothing. Then on the way back, when the butterfly starts to move back it spikes up then comes back down. Both times I noticed a momentary jump of voltage in the wrong direction too.
I haven't hooked STAR back up, but I have done the TB voltage test with it in the past and it passes just fine, so the ECU thinks everything is good (and also explains no codes).
What should my next testing steps be?
*Edit: I just realized I have WIS on my laptop, and looking at the wiring diagram the power and ground should be pins 1 and 4 as the posted pic indicates. So I have no idea why I'm seeing something different. I can confirm I have 5v power to pin #6 with the harness unplugged, directly contradicting the wiring diagram, confirmed by location as well as color. I'm assuming this is sent by the ECU, so is this enough to condemn my ECU?
I just don't understand why this wouldn't set any faults.
STAR shows the voltages correctly, topping out when the throttle plate does so mechanically, and the accelerator pedal voltages are a smooth sweep all the way to kickdown.
This means that the learning process for the throttle stops is not being done correctly, and I can physically watch that happen as it only opens part way then shuts again during the learning process. The other test in STAR for proper signals to the potentiometers requires an ECU wire harness adapter (which I don't have), but says that if the voltage isn't right, the only remedy is ECU replacement...
So here are my options as I see it:
1) Buy a used ECU and have someone program it (or maybe my STAR unit can do this??)
2) Buy the $100 special adapter, test the circuit per STAR to confirm the ECU is needed.
3) Pull the supercharger so I can inspect the entire wiring loom for breaks or corrosion.
We know it can't the TPS itself, since I've tried two and one was known to be good on another car. The accelerator pedal was replaced last year, and voltage sweep and values are spot on. To me that just leaves the above possibilities.
Open to suggestions!
I can have my supercharger out in about 30 minutes, however, checking the harness requires cutting the rubber shielding open which is quite invasive and will likely damage the wires in the process. Last I checked a couple years ago, there were a few harnesses available from MB for around $600 retail.
I definitely wouldn't chance trying to have someone 'fix' the ecu, and I'd likely try the harness first anyway and see if things clear up. I've gotten quick at pulling the SC with my engine hoist, I'm just bitter about it haha.
Do you think it's a safe bet though to have a used ECU recoded to my car? I sent an email to Tony at RaceIQ asking if he did that kind of work, and I've seen a few places advertising that service for about $200. I have STAR w/ developer mode, however I have no idea how to use that feature and I think you still have to have a subscription to the dealer network to get new SCN coding.
Correct on the SCN coding, dev mode won't help you. Other than a new ECU you may try a used one and have the VIN wiped by an outside company. Then a dealer would have to do the basic programming. This doesn't always work right and by the time you pay for all that, and the hassle factor, you've almost paid for a new ECU.
So, I should just order and replace the harness. If it still has an issue, then we can point to the ECU. If it's fixed, then yay! I don't have to buy an ECU.
As a footnote: The channel under the supercharger had a bit of oil in it after I bought the car, enough that I think some of the loom was sitting in it. I cleaned it the first time I had the SC off, but it makes me wonder..
Also, don't overlook your fuel system before you condemn the ECU. Low fuel pressure, and/or large swings in fuel pressure (i.e. faulty dampener )can play havoc with these cars.
I just can't see the justification of spending 2-3 hours of diagnostic time (about the same price as a new harness) to get me to the same conclusion. Plus the car is 'modified' and I've known too many techs who start going down the rabbit hole or have pre-judgement and spend more time grumbling than treating it like another patient.
I can get the harness for just under $500 and it's an afternoon of work for me so not a big deal, and it will be nice having refreshed connectors as so many of mine are brittle and some have cracked (I've got zipties around most of my ignition coils as a backup since those plug clips were broken off before I bought the car).
It's rare that they go bad so I make sure with all the testing as they are expencive and time consuming to replace.
Now it appears to be the ECU. I figured I'd do some more testing since I was planning on replacing the harness anyway, I spliced into the wires at the ECU to bypass the harness and that also gave me some nice 'meat' to read voltages vs back probing with a paperclip.
The short story is that the TPS supply is only receiving 1v (ignore the (-), I had this swapped around when taking the picture, I really need alligator clips that have different colored wires haha. And I know it looks like a rat's nest, but all connections were rock solid so I can trust the readings).
Per WIS (below) their possible causes are cable and ECU, and since we bypassed the cable that leaves nothing else. My readings on the potentiometer values are all over the place but based on my understanding the power supply should be a steady 5v at all times, and the TPS uses this as a reference, so the fluctuating voltages on the other wires can't really be trusted. Plus it acts the same on both of my throttle bodies.
I know you guys chimed in to keep me honest and open to other possibilities, but as a tech would you suggest anything else at this point based on these findings? I can't seem to think of anything. Ugh.
Nope, no change unfortunately, there are two according to my little sheet (15a near ECU and 7.5a inside cabin), still the same readings.
