Airmatic front strut question
I'm replacing the front Airnatic struts on my E55, as a preventative measure. I'm going with new Bilsteins. The left side I got at a fair deal from an online commercial seller, but the right side was from a private eBay seller, at a price too good to true! It is new, appeared to be in good as new shape, but in a beat up box.Went to install it it, and found that it is not pressurized. Also, it's been collapsed a couple of inches. And it fails the wiggle test, which both Bilstein, and Mercedes calls out as being defective, or scrap. Has anyone here dealt with this issue before? I plan on returning it, and buying a fresh right side strut, this time. Live and learn.
Received 1,489 Likes
This place is a joke.
The struts will lose air pressure after being stored a long time, just like your tires. When I replaced both my fronts with Arnotts, I also got a great deal on one side. When I got it, it was new and never installed, but the production date was some 4 years old, it had been sitting on a shelf. The rubber bellows was soft, no pressure at all. Arnott's instructions tell you to check this before installing. I went ahead and used it, and had no problems, no leaks, afterwards.
I've never heard of the wiggle test, but take MB's WIS with a grain of salt. There is a lot of German engineering fantasy in there.
