Looking For Larger Y Pipe
I posted in the for sale/wanted section but I know not everyone here checks that.
I've got an 82mm throttle body on the way, hoping to find someone who might have the SL Y pipe, massaged/modified or not, to sell to me (or other similar setup, I can't remember if there were other models that had the larger inlet).
Thanks!
Thanks!
When I checked I only saw new ones on Ebay, some list 'SL' in the description but when you look at the listings they are off of E55 and are the smaller pipe that I already have.
I was also under the impression that the stock 74mm shouldn't be modified/used on the 82, you could really work the opening but the overall airflow would be lower and could restrict the added flow potential. One of the advertisers was to modify the SL pipe as those are technically 80mm and need a little massaging to make work (which I'm planning to do as needed).
