Tune and pulley question.
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Car is bone stock except for a new 010 pump upgrade and XL PLM heat exchanger. I want to run a 76- or 77mm pulley and a tune maybe for a couple months. When I get a couple projects knocked out and I have more time I will put on a larger TB and Long Tubes (MBH) and re-tune. Do you think I can I get by with a tune and a 77mm pulley? I drive like an old man 99% of the time and if I do a pull it's usually a two gear pull, second and third gear pull at the most.
Thanks for your wise wisdom in advance...
Chris
Chris
Fountain35 (01-11-2021)
